My router, an Asus rt-86u, supports being an OpenVPN server. At first I had it configure to only allow me to access my LAN whenever I connected to it. That worked fine.
Now however, I want to be able to route internet traffic through it as well. When the adjustment to allow internet traffic to be routed through my OpenVPN server and connect, my client devices always time out whenever they make a request to any web page. I am under the assumption that I did not configure something that should've been configured in my router.
Can anyone help me out?
Thanks!
Windows 10 Edu | Asus ROG Strix X570-F Gaming | Ryzen 9 3950x | 4x 16GB G.Skill Trident Z RGB| ROG Strix GeForce® RTX 2080 SUPER™ Advanced edition | Samsung 980 PRO 500GB + Samsung 970 Evo Plus 2TB + 8TB Seagate Barracuda | EVGA Supernova 650 G2 | Alienware AW3418DW + LG 34uc87c + Dell u3419w | Asus Zephyrus G14
https://linustechtips.com/topic/1116653-openvpn-configuration-help/
Could you post the configuration file contents? Kind of hard to tell you what's wrong without knowing how it's set up.
Could you also let us know your default gateway IP so we know where it is. Block any public facing IP addresses if you have any in the configuration.
EDIT: looking a bit more into the configuration for OpenVPN, we shouldn't need your default gateway, so you can leave it out if you wish.
My default gateway ip is 192.168.50.1
And thats my configuration.
-snip-
Try disabling respond to DNS in the settings. If that doesn't work, disable advertise DNS to clients as well get the clients to use their own DNS servers, through the VPN.
I'd be interested to see if you can ping an IP address when connected to the VPN with the current config. Try 8.8.8.8.
I will give this a shot and see what happens.
I tried both configurations.
Chrome shows could not find DNS before immediately switching to cannot connect to page or a similar message.
I tried pinging 8.8.8.8 from the command prompt and I get request timed out
Also OpenVPN shows kb of data being sent out, but nothing coming in.
I was able to figure it out. The issue dealt with compression. For some reason changing the compression method allowed full speeds into my own network
