Probably neither considering FX is pretty much obsolete now, can you check how much would it cost you make a build around the Ryzen 3 1200 instead?
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1116625-first-gamingediting-pc/#findComment-12990514
The 970 is basically a 1060 with more ram, so the performance of these PCs would be really similar overall.
But as mentioned, Ryzen is where it's at these days.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1116625-first-gamingediting-pc/#findComment-12990521
3 minutes ago, Jordiee9595 said:
I only have £350 tops
can you save up more? No point buying any of those systems mentioned in your post, for what you want to do with it.
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1116625-first-gamingediting-pc/#findComment-12990553
