3 minutes ago, LapisMarker said:
Hey, so i'm a new builder and I would like to ask if the SilentiumPC Spartan 3 Pro would fit in the Fractal Design Core 1000, btw I have a Ryzen 5 2400g, and will be putting an RX 570 8gb soon. I will be overclocking the cpu.
 It should the cooler is 135mm tall and the max height for the Core 1000 is 148mm.
https://www.silentiumpc.com/en/product/spartan-3-pro-he1024/
https://www.fractal-design.com/products/cases/core/core-1000/black/
https://linustechtips.com/topic/1116556-does-it-fit/#findComment-12989974
Oh, ok thanks.
https://linustechtips.com/topic/1116556-does-it-fit/#findComment-12989977
