ignore it, you can't use the extra power it would provide anyway. A single 8 pin already pushes over 350 watts.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1115438-asking-for-help-again/#findComment-12980941
You have the Answer right there. You want a 24 pin plus a 4 pin connector for your Mainboard.
You could buy a  8pin to 4+4pin adapter or simply buy a fitting PSU. The Corsair RM650x would be my choice in your price range.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/1115438-asking-for-help-again/#findComment-12980959
The motherboard has a 8+4 pin for the CPU. However the normal 8 pin connector can deliver more than 350w. So the extra 4 pin isn't really necessary. Not even the 3950x can draw that much power. Just use the 8 pin connector will be enough for OP.
https://linustechtips.com/topic/1115438-asking-for-help-again/#findComment-12981150
