FiiO E10 volumen changing buzz
Go to solution Solved by Heisenbleurgh,
change the gain to low
this makes it less noticeable, thanks!
My E10 does this as well, I don't think it's anything to worry about.
thanks, wanted to see if it was just mine :)
Ususally a bad connection somewhere. you could RMA it, but I don't think it's too much to worry about.
Static or buzz? Working the volume pot up and down a few times may help temporarily; opening up the unit and applying contact cleaner to the pot may be a more lasting solution.
pretty sure it's just buzz. I don't find it loud/annoying/frequent enough to be worth going through the trouble of returning unless it was a big deal it since I'm not in the US.
And I was actually curious of opening it up, I might just do that one of these days :P
thanks everyone!
Hi guys, I've been having an occasional buzz while adjusting volume on the E10. Works fine and only happens sometimes while adjusting the volume so it's not really something that constantly bothers me, at least not enough to consider it defective but just wanted to know if anyone's had similar issues with this or maybe another amp/dac?
[spoiler=pc specs:]cpu: i5-4670k | mobo: z87-pro | cpu cooler: h100i | ram: 8gb vengeance pro | gpu: gtx770 ftw 4gb | case: nzxt switch 810 matte black | storage: 240gb ssd; 1tb hdd | psu: 750w corsair rm |
keyboards: max nighthawk x8 mx brown + blue led; corsair k60 mx red; ducky shine 3 tkl mx blue + orange led | mouse: deathadder black edition | audio: FiiO E10; sennheiser hd558; grado sr80i; sony mdr-nc200d; blue snowball |
https://linustechtips.com/topic/111510-fiio-e10-volumen-changing-buzz/
CPU: i5 2500k @4.3GHz  |  Cooler: Corsair H100i | Ram: Corsair Vengeance 8GB DDR3 1600 MHz | GPU: Asus DC2 GTX 570 | Mobo: Asus P8P67 EVO | Case: Corsair Carbide 500r | Boot Drive: 120GB OCZ Agility 3 | Games Drive: 2TB WD Green| OS: Windows 7/OSX Mavericks (Hackintosh) | Monitor: LG EA63V x2 Soundcard: Fiio E10 | Keyboard: Corsair Vengeance K70 (browns) | Mouse: Corsair M40
thanks everyone!
Mine started doing it after I was dinking around with a solder gun and burnt out the LED circuits, which are right next to the volume pot's. Probably just a bad solder job on your unit.
