hello im looking at 2 motherboards atm to buy going with a 2600 for my mini lan pc.
my other parts are:
CPU: ryzen 5 2600
psu: 550w sfx evga superNOVA
Ram: g.skill ripjaw cl16 3466mHz 16GB
GPU: 1060 6GB (will be upgraded in the future to a 5700)
Case: SilverStone MILO ML08B
now the mother boards are:
B450: MSI B450I GAMING PLUS AC
X370: ASRock Fatal1ty X370 Gaming-ITX
the price on these is basically the same price so dont factor that in and i do have a 1700x if i need to update bios so dont worry about that either now before you tell me to get a 3600 or 3600x i am getting the 2600 from a friend for a much lower price and it will be worth as its not supposed to run top games only a couple of lan games and e-sports titles at 144fps which it can no problem
https://linustechtips.com/topic/1115041-building-itx-lan-pc/
B450 board is better
Desktop benching:
https://linustechtips.com/topic/1115041-building-itx-lan-pc/#findComment-12978201
3 hours ago, Deli said:
There is only one B450/X370 itx motherboard worth buying. The MSI B450 i Gaming.
False.  The Asrock B450 mini ITX boards do everything you need them to do. Especially with ryzen.  No need for insane VRM, no need for insane OC.  If you are looking at the SFF mobos, asrock B450 do the job, no issues, and can easily handle all the ryzen stuff.  The only thing I havent tried on mine are 3900x at this point, and I have seen build where it works (with proper cooling).  2 systems, not a single complaint here, they do what they are supposed to
El Zoido:  9900k + RTX 4090 / 32 gb 3600mHz RAM / z390 Aorus Master
The Box:  3900x + RTX 3080 /  32 gb 3000mHz RAM / B550 MSI mortar
https://linustechtips.com/topic/1115041-building-itx-lan-pc/#findComment-12978642
