RX 580 NO POST!!
Go to solution Solved by DejaVoodoo,
Did you re-seat the card and connections?
So I was playing PUBG in this brand new(arrived today(17/10/2019)) after installing the amd driver software and all drivers for the PC, this Asus RX 580 4gb dual OC  stopped posting, and this white led light has been on from the beginning (since it was first plugged in). It's installed on a NOX Hummer MC with the all fans(2 in front(stock fans) + 3 deepcool RF120 + Enermax TB silence(120mm)). Anyone has a clue of what happened?
** The RX 580 was freaking hot to the touch when it stopped posting, think it's overheating issue**
*There is no fan spinning when it's turned on*
https://linustechtips.com/topic/1114761-rx-580-no-post/
18 minutes ago, jaiminator21 said:
yep now working again the problem is this pc is a heat factory
What's your case?
Your GPU probably just has a 0rpm mode where the fans won't spin until it hits a certain temperature.
https://linustechtips.com/topic/1114761-rx-580-no-post/#findComment-12975961
7 hours ago, Streetguru said:
What's your case?
It's the nox hummer MC with all the fans(5). And maybe the fans of the GPU where the problem. Now I've changed it and in PUBG max settings in Erangel after 4 games it reach 70°C,
https://linustechtips.com/topic/1114761-rx-580-no-post/#findComment-12976628
4 minutes ago, jaiminator21 said:
nox hummer
I can't even see any gaps for airflow, it'd do much better without the front panel, or without the side panel installed.
https://linustechtips.com/topic/1114761-rx-580-no-post/#findComment-12976633
