Hi,
so I have been getting frametime spikes and stutters and microstutters across almost all games on 5 different PCs,
4 prebuilt and 1 built by me, I have tried reinstalling windows 10 and buying both windows 10 home and pro again, I have tried 4 different moniters, 60hz, 120, 144hz, and 240hz and at 4 different locations,
It happens in offline and online games, I have tried VSYNC, GSYNC,
Adaptive Sync, Capping FPS below hz rate, Almost every nvidia control panel variation, reinstalling drivers,
installing old drivers, new drivers, reinstalling windows, buying new windows, replacing every cord,
tried different keyboards and mouses, updating bios, different bios settings, xmp off, on,
so I figured it might be a power issue so I had an electrician come by and rewire the outlet and connect it straight to the breaker and that did not fix the issue so I also tried a power conditioner, a UPS, multiple surge protectors,
and many more thing that I cant think of at the moment to try to fix this issue,
I have had this issue ever since I got my first pc 3 years ago,
I understand if you could not help me with this,
In that case could you please refer me to someone who can, Thank You
https://linustechtips.com/topic/1114130-please-help/
1 minute ago, Genwyn said:
Yeah, Windows is the inherent root cause of microstutter these days for 99% of people’s problems with it. It’s not a stable OS and every version will act differently.
I would suggest trying an enterprise or locked, barebones version of it, maybe LTSC.
If your system has windows 7 drivers available, use windows 7.
Or unironically 8.1 if possible.
If your games run on if, try Linux.
I can’t tell you to pirate an old version of Windows just to try it and see if it solves the issue, but I can tell you that it would be really dumb to outright buy any old version of Windows, even if they don’t have a trial period active anymore.
People are generally expecting of stutter these days because it’s kinda just the norm now. Games stutter, what causes it? Lots of things, mainly windows. How can you fix it? Probably can’t.
ok heres why i dont think its windows, because i bought a prebuilt from nzxt and they tested it and it was smooth before they sent it out and when i plugged it in it has the same issue as the pc i already had.
https://linustechtips.com/topic/1114130-please-help/#findComment-12970216
Have you tried one of these systems at someone else's place? I've had systems come in that had similar issues at the clients place but not here. It's pretty rare but sometimes bad power from the wall causes this apparently.
https://linustechtips.com/topic/1114130-please-help/#findComment-12970236
ive tied at 3 different locations 2 of them were the same but 1 of them if was a little better but was still happening. I also thought it was power so i had the outlet rewired and grounded and plugged to its own breaker and i have tried a power conditioner different surge protectors and a ups, UPS seemed to help but didnt resolve it either.
https://linustechtips.com/topic/1114130-please-help/#findComment-12970243
Have you tried someone else's rig and played on that for a bit?
https://linustechtips.com/topic/1114130-please-help/#findComment-12970252
  • 8 months later...
