Hi all! I'm looking into making a PC. This will be my first time stepping into the PC gaming world and I want to get a good starting point! With the help of videos and one of my more tech savvy friends I've put together a list of parts that I think should work together! But just to be safe thought there would be no harm posting it here to get loads of other opinions and thought! So I'm UK based, building it to mainly game (so long as I get decent experience on new AAA titles I'm happy starting here) I will be looking at future updates as needed.
Component   Selection Price
CPU   c7baf2c9c9cc15ae23adb24c2f4316fc.256p.jpg AMD Ryzen 5 3600X 3.8 GHz 6-Core Processor £217.98 Buy
Motherboard   8d7d0435e8a2af93b5d91a1a5dccd476.256p.jpg Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard £218.47 Buy
Memory   51rypl%2BNdmL.jpg Patriot Viper Steel 16 GB (2 x 8 GB) DDR4-3000 Memory £69.98 Buy
Storage   51UvGNMLj4L.jpg Seagate Barracuda 3 TB 3.5" 7200RPM Internal Hard Drive £56.99 Buy
Storage   41UKoJx2tZL.jpg Kingston A400 240 GB 2.5" Solid State Drive £27.64 Buy
Video Card   4162pP5uCxL.jpg PowerColor Radeon RX 5700 XT 8 GB Video Card £360.79 Buy
Case   e09b227eac8d09ae71212336a103382d.256p.jpg Silverstone RL06 ATX Mid Tower Case £69.98 Buy
Power Supply   02951377c9eed1e21fc3d8ba6092717e.256p.jpg Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply £84.98 Buy
Monitor   4c261f785cd346d82181fe59c15ccc5d.256p.jpg Acer XF240H 24.0" 1920x1080 144 Hz Monitor £179.97 Buy
Total: £1286.78
I do have a preference to AMD and the radeon GPU as the monitor is apparently more compatible with it ? I may be wrong but it's also cheaper and lowers the cost by a bit. I'm spreading it over 2 months getting most of the cheaper parts in November and then the GPU PSU HDD and motherboard in December. Any reassurance that this will work once put together would be mega or if you see any fault in the plan the even better!!
Thanks for reading this time and bearing with an idiot! :D
IrishGamer34
Edits
Motherboard: After going back over and checking with the motherboard I saw that the one I originally put in wasn't compatible with 3rd Gen Ryzen so I had to swap it out in favour for the one that's now in there. This will also allow for more room to upgrade in the future though to a better CPU
* After looking up some reviews on it I found a comparison between this MoBo and 4 others and this did the worst so I now gone with the best resulting one at a slightly higher price but still offering a better upgrade path and cooler overall PC
Case: I changed the case as it's a slightly better model, just in white, and it's cheaper by about £30 as well
Monitor: There was some false information on amazon for the monitor about it being 144hz so I now changed it to the current Acer listed
Edited by IrishGamer34
Described in forum
https://linustechtips.com/topic/1114043-my-first-build-idea/
