Using 2 PSUs
Solved by Spotty,
4 minutes ago, Supportsneedlove said:Can I use my CX550M outside my case while only plugging in the 8 pin for the GPU?
Why not just use the CX550M for the entire system? No problem running the PSU outside of the case, just plug in the CPU, Motherboard 24pin, the PCIe to the graphics card and any sata power cables needed for drives.
What you're trying to do is possible, but it'll be more effort and more janky than just powering the system with the CX550M. I wouldn't recommend it.
