I have an 8pin + 4pin power connector for the cpu, would it be bad if I only run the 8pin?
All I ever do at this point is play Destiny 2.  ¯\_(ツ)_/¯
It's kinda sad...
CPU: AMD Ryzen 5 1600x
CPU Cooler: Corsair H100i v2
MB: Asus PRIME x370 Pro
RAM: Corsair Vengeance LPX (2x8gb) 3200 MHz
Storage: Toshiba P300 1TB, Samsung 970 EVO 250gb
GPU: EVGA GeForce GTX 1070 ti GAMING
PSU: Corsair RMx 750w
Case: Corsair Crystal 460x
https://linustechtips.com/topic/1112644-cpu-power-connectors/
What motherboard and cpu? The extra 4pin is usually not needed and only useful for extreme oc'ing.
https://linustechtips.com/topic/1112644-cpu-power-connectors/#findComment-12958592
Ryzen 3 1300x, msi motherboard
It's kinda sad...
https://linustechtips.com/topic/1112644-cpu-power-connectors/#findComment-12958595
Yep, the extra 4pin is far from necessary.
https://linustechtips.com/topic/1112644-cpu-power-connectors/#findComment-12958600
