problems with gpu overheating
Solved by LogicalDrm,
First, please try to use punctuation. It helps to understand your problems better.
Now to issue. You have multiple things effecting there. First is the case which has poor airflow (you can watch Gamers Nexus review for example). Secondly you have AIO as intake. While this will be better for CPU, it also means that GPU doesn't get as much fresh air as it would without it. Thirdly you have M.2, a hot component, next to GPU. Less airflow overall + less fresh air + hottie next to GPU. I think that sums it.
Fixes. Move AIO to the exhaust (top). Remove front panel of the case. Increase GPU fan speed.
