[Recommendations] Small Box HTPC
Solved by Dujith,
Any of the Intel NUC's will do.
I would recommend an i3/5 version, that will be enough even for 4K as that is handled by the iGPU anyway.
There are alot of configurations, kits and barebone. Just look out for the one with IR so you can remote control them without needing an app.
denizayciceks ·
Posted in Troubleshooting7 -
5
Macaw ·
Posted in Console Gaming5 -
4
2
Shahrad ·
Posted in LTT Releases9 -
9
