I have an asrockb450 pro 4 with bios p3.30, an msi rtx 2080 oc 8gb, ryzen 7 3700x, and four sticks of ddr4 3200 gskill ram, also I have a seasonic 650 whatt 80+ gold. My problem is my ram will not get 3200 stable and autos to 1866, and when I manage to get it to post or boot it freezes at random times (anywhere from five minutes to an hour). Can someone help me solve this also the computer beep once after shutting down (with no speaker) and the cpu autos to 1.10000 v. And won’t even boot unless I have it at least 1.25 or more
https://linustechtips.com/topic/1111900-help-with-pc/
manually set the ram speed and latency and voltage written on the side of the ram sticks in your bios. if it is still not stable try to push a little more voltage than stock till it is stable.
Main Rig: CPU: AMD Ryzen™ 9 3950X Processor (Stock, -0.1V offset)  /// Motherboard: Asus Pro WS X570-Ace /// CPU Cooler: Deepcool GamerStorm Castle 360 RGB V2 /// GPU: Gigabyte AORUS GeForce® RTX 2080 SUPER™ 8G /// RAM: G.SKILL Ripjaws V 128GB (4x32GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R6 USB-C Blackout TG /// PSU: Corsair RM850i /// Storage: 500GB Samsung 970 EVO Plus NVMe (boot) + 1TB WD Black SN750 NVMe (Working Drive) + 2x 1TB Samsung 850 EVO 2.5" SATA SSD RAID0 (Game Library) + 2TB Seagate BarraCuda (Backup) /// OS: Windows 10 Pro
Peripherals (Main Rig): Mouse: Logitech MX Master 3 + Logitech G903 Lightspeed /// Keyboard: Keychron Q1 ANSI - JWK Lavender Linear Switches (TX Switch Film, Krytox 205g0), Durock V2 Stabilisers, Polycarbonate Plate, Tape Mod, GMK Blue Samurai + Keychron K4 V2 Hotswap RGB Aluminum Frame - Gateron Milky Black (Deskeys Switch Film, Krytox 205g0), Foam Mod, Tape Mod, GMK Rainy Day PBT Clones /// Tablet: Wacom Intuos M BT /// Monitor: 4x LG 27UL500-W (4K IPS Freesync) /// DAC: Focusrite Scarlett 2i2 /// Speakers: Logitech Z625 /// Mic: Focusrite CM25 MkII /// Headphones: Audio-Technica ATH-M50x, ATH-LS70iS IEMs /// Racing Wheel: Logitech G920 Driving Force with Shifter /// Eye Tracker: Steelseries Sentry  /// External Drives: 500GB Samsung T5 SSD (Working Drive)
Home Server - NASty: CPU: AMD Ryzen™ 7 2700x Processor /// Motherboard: Asus PRIME X470-Pro  /// CPU Cooler: be quiet! Dark Rock Pro 4 /// GPU: Gigabyte GeForce® GT 1030 OC 2G /// RAM: G.SKILL TridentZ RGB 64GB (4x16GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R5 Window /// PSU: Corsair RM750x /// Storage: LSI SAS 9211-8i (IT Mode) + 10x 4TB Seagate Exos Enterprise Drive /// OS: UNRaid
Tester Rig: CPU: AMD Athlon™ 200GE Processor /// Motherboard: Asus ROG Crosshair VI Hero WIFI  /// CPU Cooler: AMD Wraith Prism RGB /// GPU: Palit GeForce® GTX 1050 2GB StromX /// RAM: Klevv Bolt 8GB (1x8GB) 3000Mhz CL15 /// Chassis: The AMAZING $30 "Computer Case"! /// PSU: Seasonic Focus GX-750 /// Storage: 1TB Samsung 860 EVO 2.5" SATA SSD + 240GB Transcend SSD220S 2.5" SATA SSD /// OS: Windows 10 Pro
Laptop (Asus UX430UN): CPU: Intel® Core™ i7-8550U Processor  /// GPU: NVIDIA GeForce MX150 /// RAM: 16GB 2133Mhz /// Storage: 512GB SanDisk SD8SN8U512G1002 (boot) /// OS: Windows 10 Home
Other Tech: Console: Xbox One S 1TB, Apple TV 4K /// Printer: Canon imageCLASS MF635Cx /// Phone: Apple iPhone 12 Pro Max 256GB Graphite (Daily Driver)  /// Tablet: Apple iPad 9.7-inch Wi-Fi (2018) 32GB + Apple Pencil (1st Generation) /// Headphones: Apple Airpods Pro, Sony WF-1000XM3, Sony WH-1000XM3 /// Smartwatch: Apple Watch Series 6 GPS Space Grey
Cameras: Bodies: Canon EOS-1D X Mark II, Canon EOS 5D Mark IV,  Sony A6000 /// Lenses: Canon EF 24-70mm F/2.8L USM, Canon EF 16-35mm F/2.8L II USM, Canon EF 70-200mm F/2.8L IS II USM, Tamron SP 150-600mm F/5-6.3 Di VC USD G2 (Canon), Sony SEL-P1650 E 16-50mm F3.5-5.6 PZ OSS /// Lighting: 2x Godox SL60-W Continuous LED, 2x Canon Speedlite 580EXII /// Tripods: Leofoto LS-324C Carbon Fiber Tripod + Leofoto LH-40 Ballhead, Leofoto MC-80 Multipurpose Clamp, Triopo DG-3 Gimbal Head /// Yes, I am a Canon Fanboy, deal with it
https://linustechtips.com/topic/1111900-help-with-pc/#findComment-12952335
what software are you using to get this number? The lowest should be 2133, 1866 sounds like a single data rate
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1111900-help-with-pc/#findComment-12952336
i assume you have enabled D.O.C.P./XMP
usually ram should default to 2133Mhz so 1866Mhz is pretty odd
have you tried only using one stick of your memory, one after the other, and see if there is a problem with one of your sticks?
My Rig / Buildlogs:  ❄️ SNOWFLAKE ❄️ FROSTBITE ❄️
CPU: Ryzen 5 3600   Cooler: Corsair H115i Platinum   RAM: Corsair Vengence RGB Pro 16GB @3200   Mobo: Asus Prime X470 Pro
Graphics Card: Gigabyte Aorus 2080super Waterforce    Case: Corsair 500D   PSU: Corsair HX850i
Storage: 500GB Crucial P1 NVMe SSD, 1TB Crucial P1 NVMe SSD, 2x 1TB SATA SSD
Displays: AOC CQ32G1 32" 2560x1440, Acer XB280HK 28.0" 3840x2160 60 Hz, Medion MD20850 24" 2560x1440
https://linustechtips.com/topic/1111900-help-with-pc/#findComment-12952339
that would explain that weird number, but that would also result to the PC "auto to a stable" 3732Mhz ^^
https://linustechtips.com/topic/1111900-help-with-pc/#findComment-12952347
I have xmp off because even with it on I tried 2133 it will sometimes boot but then it freezes also I tried 1 with 3200 and it booted but froze later
https://linustechtips.com/topic/1111900-help-with-pc/#findComment-12952372
3 minutes ago, Devvv said:
Thats the number in the bios
do you have other XMP profiles like 2800 or something?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1111900-help-with-pc/#findComment-12952374
so you just enabled XMP, didnt touch any other option and it crashes?
https://linustechtips.com/topic/1111900-help-with-pc/#findComment-12952379
25 minutes ago, Devvv said:
Yea other then setting the cpu to 1.25
well i guess that there is someting wrong with either one or more of your ram sticks or your mobos ddr4 slots. thats the only thing that would make sense in my mind.
are you sure that it is the ram causing your random shutdowns and not something else like cpu temps getting too hot?
does your machine just freeze and turn off? is there any bluescreen or errormessage?
EDIT: also: do you have any other ram you could try to use? a different 3200 kit would be optimal
also also: try updating your bios. i read a few threads over at the asrock forums now and there, according to them, was a faulty m.2 implementation which caused weird ram behavior (how ever that goes together is beyond me)
and make sure to test each stick individually.
gotta go to bed now ^^ hope to read everything worked out well in the morning
https://linustechtips.com/topic/1111900-help-with-pc/#findComment-12952396
Okay guys so far everything is working the way I want it, I am assuming that the reason was a dead ram stick in a2 because I tried the same one by itself and it froze after a bit now I’m using the other sticks I bought of the same brand and it seems to work
https://linustechtips.com/topic/1111900-help-with-pc/#findComment-12953668
