So about a month ago I got a 5700xt and admittedly I've pretty much been playing csgo for this whole time on it, so i didnt really notice the problem until I started to play some Far Cry ND and I the performance was terrible. I looked into it and it looks like the clocks are only staying at about 900-1100mhz, making 1080p ultra run at 50-70fps max. Any ideas or is it just driver problems... still...
Gaming Rig:
CPU: Ryzen 7 3700x  Cooler: Wraith Prism    RAM: 32gb G.Skill Tridentz RGB 3200mhz     Mobo: Asrock X570 Taichi
Graphics Card: Powercolor Red Devil RX 5700 XT     Case: Fractal Design Meshify C Dark TG     PSU: Corsair RM850x
Storage: 250gb Samsung 960 EVO, 2TB Seagate Barracuda
HTPC/VR Rig:
CPU: Ryzen 5 1600     Cooler: Noctua NH-L9a     RAM: 16gb Crucial Ballistix Sport 3200mhz     Mobo: Gigabyte B450 Aorus Pro Wifi ITX
Graphics Card: Powercolor Red Devil RX 580 8gb     Case: Fractal Design Node 202     PSU: Corsair SF600
Storage: 120gb Kingston A400, 500gb Samsung 860 EVO
Streaming Rig:
CPU: Ryzen 5 1600 @ 4ghz OC     Cooler: Cooler Master Hyper 212 Black Edition    RAM: 8gb Corsair Vengence LPX 2400mhz     Mobo: ASRock B450 Pro4 MATX
Graphics Card: Powercolor Red Dragon RX 570 4gb     Case: Inwin 301 White/Blue     PSU: Evga 450BR
Storage: 240gb Crucial BX500, 1TB Seagate Barracuda
https://linustechtips.com/topic/1111632-5700xt-not-boosting-properly/
2 hours ago, GoldenLag said:
How does it perform in the ingame benchmark?
Edit: does lowering from "ultra" to "high/medium" yield any increase in framerate
Are there stuttering issues?
In game benchmark performs about the same while bumping down the settings barely yeilds any increase in performance. As far as the stuttering, ive only had issues in csgo but even then they go away after a while. It doesnt do this in something like furmark, as it will boost to well over 1900mhz all day, but it does in other games. Ive tried messing around in wattman, yeeting the power slider to 50% but even then its still having issues.
Gaming Rig:
HTPC/VR Rig:
Streaming Rig:
If you get about 100fps to start with and about 60-70fps (100fps to start with) in the ingame benchmark, then you are probably CPU limited.
The stuttering in CS;GO. How far are the framedroos
Does it boost properly in other games?
What CPU are you using, and what RAM are you using? Is the RAM in single channel or dual channel mode?
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
The cpu usage was only about 40-50% and so was the gpu, the framerates in csgo was ok and would only drop after a round just ended/began and would drop to 130ish while staying a consistent 180-200ish. I wouldnt really think a 2600x would bottleneck a 5700xt that much would it. Seems like the gpu just acting up as in csgo gpu clock would drop to 650ish mhz at times.
Specs in signature and rams in dual channel
Gaming Rig:
HTPC/VR Rig:
Streaming Rig:
Thats just a CPU bottleneck
No CPU can keep up with a gtx 1060 in CS;GO.
Iirc it doesnt, bUt i havent doublechecked, but it seems you are getting the performance you should be getting.
Also CPU usage looks at all cores, Far Cry just hasnt been good at using that many cores.
Id have to doublecheck with a CPU benchmark, but 70 fps is pretty good.
I've had issues like this before where my AMD card was stuck with 2D clocks in some games (e.g. Shogun 2 Total War). I had to create a profile and hot-key it to force 3D clockspeeds. It's been a while since I had to do that and AMD drivers have changed a ton since then.
Idk, ive looked at other benchmarks at 1440p and people are getting upwards of 100fps easily but at 1080 im dropping down to 45fps at times. usually hangs around 60fps.
Gaming Rig:
HTPC/VR Rig:
Streaming Rig:
On the same hardware?
Or a GPU benchmark?
Or a GPU benchmark?
On better hardware (9700k iirc) but they were still boosting up to 18-1900mhz
Gaming Rig:
HTPC/VR Rig:
Streaming Rig:
5 minutes ago, GoldenLag said:
The roughly expected performance is the same for the, 2600.
Performance should hover around 70-100 fps.
So it seems you are getting a little low performance.
oof dang, doesnt really do this in other games but FC ND for some reason. Thanks for your input tho.
Gaming Rig:
HTPC/VR Rig:
Streaming Rig:
Care to run these benchmarks when you have time?
Cinebench R15/R20 for CPU performance
Aida64 Memory Benchmark for RAM performance
Superposition or 3DMark Firestrike for GPU performance.
You can download free version for all these.
