Possible to have 2nd GPU do folding and First for general use?
Go to solution Solved by SkyHound0202,
You can manually set up the folding slot(s) in the configuration by changing the GPU index from -1 (default) to a desired value (0 or 1, depending on which card you want to reserve)
"Mankind’s greatest mistake will be its inability to control the technology it has created."
Perfect~! I havent put it in yet, more making sure it would be easy or not, but it seems it will be! Thanks!
Moist
