the i5 7600k is better for VR than the 2600 due to faster single threaded performance, and VR titles generally are not able to leverage many cores. Are you sure you are being bottlenecked by your CPU?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1109697-plz-help/#findComment-12933739
9 minutes ago, b322 said:
yes my gpu is at like 40% and my cpu on 100%
Doesn't necessarily mean you're bottlenecking, it could just be a CPU-heavy game.
If I were you I'd buy an i7 instead of a whole new platform. If this was a new system I'd suggest Ryzen but since it's an upgrade, just stick with Intel for now.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1109697-plz-help/#findComment-12933775
That's a cpu bottleneck.
I say get a 2600 for 2 extra cores and 8 more threads.
https://linustechtips.com/topic/1109697-plz-help/#findComment-12933785
