Thermal paste is designed to not conduct electricity. You're probably fine. To clean it, if you like, get some rubbing alcohol on a paper towel
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1109689-i-need-help/#findComment-12933695
Unless your paste is conductive (like artic silver), it's gonna be okay.
Just wipe it clean with some rubbing alcohol.
https://linustechtips.com/topic/1109689-i-need-help/#findComment-12933700
3 minutes ago, arvid_haland said:
Im using mastergel from coolermaster
MASTERGEL MAKER
Is developed for users needing the best thermal conductivity for high performance CPUs, GPUs or even chipsets. The non-curing and non-electrical conductive traits help avoid any short circuiting and provides protection and performance for long-term use.
https://linustechtips.com/topic/1109689-i-need-help/#findComment-12933731
