Hi there, so im upgrading from a FX-9590 and Rx580 system, (yes it is warm) and am looking to switch to a ryzen 3600 non x, i don't really overclock i've compiled this with help from r build a pc, this for my new upgrade, but  just wanted to see what else you all think i could do, i don't need more storage as i dont have much to store I plan on streaming Wow, and some dream cast era games, i want to use an aio to stick with the clean perspective, and if any part of my build is overkill, i would like it to be cooling, but i don't know if the 120mm is enough or should i go thicker? the reason for the motherboard is im afraid to brick my motherboard by doing a bios flash also not owning a usb drive,  other wise i think ild go with something from gigabyte, msi or asus that color matches,  I plan to buy at Mirco center cambridge, and my max budget is 750 USD, The Graphics card i own isnt exactaly that asus, 580, mine is a acer predator branded one that is a handme down, that looks like it has a gtx 780 refrence cooler on it but in black,
PCPartPicker Part List
Type Item Price
CPU AMD Ryzen 5 3600 3.6 GHz 6-Core Processor $194.79 @ OutletPC
CPU Cooler NZXT Kraken M22 Liquid CPU Cooler $79.89 @ OutletPC
Motherboard MSI B450M PRO-VDH MAX Micro ATX AM4 Motherboard $79.99 @ Amazon
Memory Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 Memory $85.89 @ OutletPC
Storage Samsung 860 Evo 500 GB 2.5" Solid State Drive Purchased For $0.00
Video Card Asus Radeon RX 580 4 GB Dual Video Card Purchased For $0.00
Case NZXT H500 ATX Mid Tower Case $89.98 @ NZXT
Power Supply Corsair CXM 550 W 80+ Bronze Certified Semi-modular ATX Power Supply $69.89 @ OutletPC
Operating System Microsoft Windows 10 Home OEM 64-bit Purchased For $0.00
Monitor Acer G257HU smidpx 25.0" 2560x1440 60 Hz Monitor Purchased For $0.00
Monitor Asus VP247H-P 23.6" 1920x1080 60 Hz Monitor Purchased For $0.00
  Prices include shipping, taxes, rebates, and discounts
  Total (before mail-in rebates) $630.43
  Mail-in rebates -$30.00
  Total $600.43
  Generated by PCPartPicker 2019-09-27 18:49 EDT-0400
https://linustechtips.com/topic/1108448-upgrade-help/
I recommend you get a different case, the NZXT H500 series cases are notorious for bad thermals, I had one a while ago and hated it. I'd like to suggest these two for around the same price, but much better airflow and thermals.
Phanteks P400A RGB:
https://www.newegg.com/black-phanteks-eclipse-p400a-atx-mid-tower/p/N82E16811854086?Description=p400a&cm_re=p400a-_-11-854-086-_-Product
Fractal Design Meshify C White :
https://www.amazon.com/Fractal-Design-Meshify-TG-Lt/dp/B07BPP9KYD/ref=sr_1_1?keywords=fractal%2Bdesign%2Bmeshify%2Bc&qid=1569624944&s=gateway&sr=8-1&th=1
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1108448-upgrade-help/#findComment-12924680
Phanteks P400A RGB:
ehh im not a big fan of rgb, or how the phanteks, looks, and the black tg, version of the meshify is almost double my case? i was looking at the prodigy m, but it apears finding one is a pain
https://linustechtips.com/topic/1108448-upgrade-help/#findComment-12924693
I linked the white because it's only $6 more and the black is a bit more if you don't want to go white.
https://linustechtips.com/topic/1108448-upgrade-help/#findComment-12924855
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($194.79 @ OutletPC) 120mm AIO is unnecessary.
Motherboard: MSI B450-A PRO ATX AM4 Motherboard  ($79.99 @ Newegg)
Memory: GeIL EVO POTENZA 16 GB (2 x 8 GB) DDR4-3000 Memory  ($59.99 @ Newegg)
Storage: Samsung 860 Evo 500 GB 2.5" Solid State Drive  (Purchased For $0.00)
Video Card: Asus Radeon RX 580 4 GB Dual Video Card  (Purchased For $0.00)
Case: NZXT H510 ATX Mid Tower Case  ($79.99 @ Amazon)
Power Supply: Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  ($74.97 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit  (Purchased For $0.00)
Monitor: Acer G257HU smidpx 25.0" 2560x1440 60 Hz Monitor  (Purchased For $0.00)
Monitor: Asus VP247H-P 23.6" 1920x1080 60 Hz Monitor  (Purchased For $0.00)
Total: $489.73
Generated by PCPartPicker 2019-09-27 22:42 EDT-0400
https://linustechtips.com/topic/1108448-upgrade-help/#findComment-12925011
