Hello,
I am a long time watcher of LTT and finally decided to join the forums because I have a question I can not find a definitive answer to.
We are ready to replace our CAD laptop workstations where I work, currently they are working on Dell Precision M6800 with i7-4710MQ CPU's, 8GB Ram, 250 Samsung SSD's and Quadro K3100M 4GB video cards. I am looking at two options to replace these computers, the first option is the Lenovo ThingPad P73 with an  i7-9750H CPU, 16GB Ram, 512 NVMe SSd's and a Quadro P620 4GB video card or option 2 would be a Lenovo X1 Extreme Gen 2 with the same CPU, RAM and HDD but with a GTX 1650 Max-Q 4GB video card instead. My questions is what really is the performance difference between the Quadro and GTX? My engineers user SolidWorks 2019, AutoCAD 219 and KeyShot for design software. Could I get them the lighter X1 Extreme and still retain the performance of the P73?
https://linustechtips.com/topic/1108395-cad-work-cards/
Hello @jrunkles1221
When the Quadro and GTX are of the same tier then the raw performance is exactly the same. But Quadro's can actually be faster in some workloads. So " It depends". LTT actually has a good video on this which you might want to see if you have not already.
https://linustechtips.com/topic/1108395-cad-work-cards/#findComment-12924237
Support to OpenCL. Drivers on Geforce and Titan only the basic OpenCL stuff while the same driver with Quadro (and Tesla) support all the advanced stuff, giving higher performance. Affects Solidworks yes tho not sure about how the lower compute performance of the P620 itself affects the final results.
Desktop benching:
https://linustechtips.com/topic/1108395-cad-work-cards/#findComment-12924257
