3600x won't post
Go to solution Solved by FOXPATH,
53 minutes ago, FOXPATH said:
I'll give that a shot, also if I were to try and snag a pcie cable. I need to get one from the same manufacturer as my power supply right? Does it matter by model?
IT WORKED!!!!!! FUCK YOU BIOS VERSION 2801!!!! YOU CAN SUCK BIOS VERSION 2703'S BIG WHOPPING PENIS!!!!!!!!!!!!! A'LJSDGHALS;GJKALGH'PAWEJIOAEH'GOAEOGBAEOK';KJSAHBIOASHTBIOAHEBTOIHAEO
Hey all, I'm new to the forum so let me know if I'm posting in the wrong area. Before I start, here are my specs:
Ryzen 5 3600x
Asus x470-I ROG STRIX (bios ver. 2801)
G.skill trident Z 16gb 3200mhz
EVGA 2080 XC Gaming
Seasonic focus gold 650w SFX-L
I am having a problem getting the computer to post after swapping my out my 1700x for this 3600x. I put in the 3600x and just get the red LED signifying CPU at the top right of the board. Fans spin an motherboard lights up. Here are the things I've tried.
• reseating ram
• testing each ram stick in each slot to determine if ram or slots are faulty
• loosened AIO
• tightened AIO
• reseat CPU
• swapped AIO with air cooler
• clear CMOS
• swapped 2080 for old HD 7800 series card
Finally I swapped the 1700x back into the board with the 7800 series card and it booted right up. It states I'm on BIOS version 2801 (which I believe is the latest). The only thing I can determine might be broken is my 2080 because it kept telling me that the PCI E power cable wasn't plugged in when it clearly was. But I don't think my graphics card acting weird would stop my system from posting... Would it?
Anyways, I'm going to bed so let me know if you need more info and thank you guys for help.
https://linustechtips.com/topic/1108263-3600x-wont-post/
If it was showing the GPU power message while doing this then the CPU is fine.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
https://linustechtips.com/topic/1108263-3600x-wont-post/#findComment-12924034
34 minutes ago, Plutosaurus said:
Make sure the PCIe power cable on the PSU side is tight.
I should have mentioned this. I did make sure that it was plugged in securely. I also tested each end of the cable with the 7800 and it works fine. So I think something is wrong with my card.
https://linustechtips.com/topic/1108263-3600x-wont-post/#findComment-12924122
Just now, FOXPATH said:
I haven't yet lol, I should probably do that huh?
Would rule out the CPU
If neither chip works with the 2080 then that's the common issue.
Also make sure you are using two separate PCIE cables for the GPU not the double Daisy chain off the single
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1108263-3600x-wont-post/#findComment-12924128
Just tested the 3600x with the 7800 and nada, still a red LED.
As for the pcie cables, I unfortunately don't have another seasonic pcie cable to test with. Think Amazon sells them?
https://linustechtips.com/topic/1108263-3600x-wont-post/#findComment-12924256
2 minutes ago, Plutosaurus said:
Try a different bios version? Maybe earliest bios that supports 3000?
https://linustechtips.com/topic/1108263-3600x-wont-post/#findComment-12924267
I know using the wrong ones can be very bad, but I don't know where to get replacements.
https://linustechtips.com/topic/1108263-3600x-wont-post/#findComment-12924277
https://linustechtips.com/topic/1108263-3600x-wont-post/#findComment-12924353
glad i could help
AMD is a bit wonky sometimes
https://linustechtips.com/topic/1108263-3600x-wont-post/#findComment-12924492
