Help please!
Solved by Fasauceome,
You'll notice quite a difference in force required after a certain point. Screwing in does take some doing, but it's very consistent. You'll feel the screws bottom out, offering a ton more resistance, which means they're in all the way. That's the target depth.
Ishikudeska ·
Xxu ·
Posted in Servers, NAS, and Home Lab0 -
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
play_circle_filled
Latest From ShortCircuit:
