PHANTEKS Universal Controller Issue?
Solved by WoodenMarker,
The 4pin headers provide a 12v pwm signal which results in 100% rpm for non-pwm 2-3pin fans. You can't control 3pin fans from the 4pin headers.
You don't need to quote yourself... Also, you can use the Edit button to add in more info instead of making another post.
kasdashd ·
1
6
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
