Hi everyone, looking for some wisdom from someone who has a good idea on GPU capabilities and what I should get. I am a twitch partner and am needing to upgrade my set up as it's been way to long. I DO NOT PLAY PC GAMES, my gf plays sims 4 now and then but that is about it. I stream sports console games so my PC is just for streaming and editing. As of not my pc is
Ryzen 7 2700x
16gb (8x8) 3200mhz
Asrock b450
650w or 750w PS
Dual monitor 1080p 60hz
GPU 750ti (yes I know but again did the job)
I am looking to upgrade my monitors to 4k or maybe just somthing better then 60hz. GPU is going to be getting a small upgrade aswell. So to run 2 4k monitors and to stream (i know a high end GPU isnt needed for streaming) what should I get for 250$ or less? My local store has a sale for a MSI radeon RX 570 8gb for 200 and also a 4gb for $150. Will the 4gb version do enough for what I need? And also any tips on a good monitor that isnt going to kill my wallet would be great aswell (bonus points if it comes in white) lol thanks.
https://linustechtips.com/topic/1107837-need-help-with-upgrade-choice/
You're doing 2x 4K monitors, you need an RX 5700/RTX 2060 or better for performance, or you're not going to have a good time.
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
