Really hoping someone can help me out here, because I'm pulling my hair out over here. I figured what better place to get help than at LTT.
I have been building systems for years. I recently put together a build for a 14 year old's birthday present. The build contains the part list here: https://pcpartpicker.com/user/SwoRNLeaDejZ/saved/Z3Hb8d
So the build went fine, everything was perfect. When I went for the first boot, there was no image on the screen. So I started to troubleshoot. When the system is booting, the motherboard has a series of LEDs that cycle during the boot process. CPU, DRAM, GPU, boot device. It goes through all of them fine and the boot device light stays on. Windows isn't installed, so not surprising. So to rule out a faulty graphics card, I popped in a GTX 970 I have, and low and behold, the system boots, posts, and everything is great. So it must be a dead graphics card. Weird, but whatever, not unheard of. So we RMA the graphics card through Amazon.
Just got the replacement card today. Installed it, booted it... And... Nothing. No image on screen again. So now I'm convinced it's got nothing to do with the graphics card and must be something else, right? What are the odds we got two dead graphics cards? Impossible right? There is a blue LED above the power connector on the graphics card that is illuminated, so I'm assuming it's getting power. My 970 was fine.
To note: I stuck the first 570 into my personal rig to confirm it was dead and it resulted in the same thing. No image on screen. That's why I assumed it was dead. Haven't tried that with the replacement yet, but I'm all ears.
https://linustechtips.com/topic/1107822-xfx-rx570-issues/
Your parts list is private - my first thought is Legacy booting vs UEFI booting for the generational differences in GPUs but you stuck it in your PC also and it didn't work.  Open up that parts list please or copy and paste
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1107822-xfx-rx570-issues/#findComment-12919507
Sorry about the link, not sure why it's private. Try this one?
https://linustechtips.com/topic/1107822-xfx-rx570-issues/#findComment-12919533
