PowerColor RED DEVIL Radeon RX 5700 - Worth it?
Go to solution Solved by I Josh I,
4 minutes ago, SPARTAN VI said:
Hardware Unboxed did a review on this exact card.
TL;DW, it's awesome but priced so closely to RX 5700 XT's that it becomes a little difficult to recommend. Looking at Newegg.ca prices, you're within $10 CAD (2% more) of a reference (blower style) RX 5700 XT, and $40 CAD (7% more) from the Asus RX 5700 XT TUF. In both cases, the 5700 XT would average roughly 12% more frames across the board
Thanks for your response. That is something to consider, spend a little more and get decently more performance.
I will give that a video a watch!
Hi all!
So I have been browsing non-reference RX 5700 cards, and out of all of them (at the moment) the PowerColor Red devil RX 5700 seems to be the best in-terms of cooling compared to the reference rx 5700. Is the PowerColor Red Devil RX 5700 the best non-reference 5700 card in-terms of cooling and quietness?
They also have a double fan RX 5700 card, but I don't believe this is out yet or at least here in Canada.
https://www.powercolor.com/product?id=1565954303
PowerColor Red Devil Radeon RX 5700 (triple fan) https://www.newegg.ca/powercolor-radeon-rx-5700-axrx-5700-8gbd6-3dhe-oc/p/N82E16814131750?Description=rx 5700&cm_re=rx_5700-_-14-131-750-_-Product
Thanks for your input!
