Hi, I'm looking to build a streaming/gaming machine with a budget of 2700-3000€. Anything that would work would be amazing. Will be playing triple A titles like Cyberpunk, also need monitors preferably 144hz 27' not necesarily 4k or anything like that. I'm from Slovenia and would buy from sites like https://www.bigbang.si/ or https://www.mlacom.si/
Thanks to everyone in advance.
https://linustechtips.com/topic/1107176-streaminggaming-machine-help/
CPU: Ryzen 9 3900X: 601.20
Cooler: Stock cooler: 0
MOBO: X570 AORUS Elite: 232.53
RAM: G.Skill Ripjaws 2x8GB DDR4 3200mhz: (x2) 173.90
Storage: Crucial P1 1TB M.2 NVMe: 128.76
              Seagate Ironwolf 3TB 7200RPM HDD: 78.71
GPU: EVGA XC Ultra Gaming 2080 Super: 911.25
Case: Fractal Design Meshify C Dark Black: 107.21
PSU: Corsair 650W RMx: 115.05
Monitor: Acer Predator 1440p 165hz G Sync: 535.29
Total: 2883.90
Total: 2883.90
Is the 2080Ti worth it or should I just buy the 2080 Super?
There are some Ti models down in the 1250 range I saw. If you saw one on a really good sale or something, it should be considered.
It is still the most powerful piece on the consumer market.
But really the FPS difference isn't massive. I think the 2080 Super is more bang for buck without losing a whole lot.
What about a comparison with a GTX 1080Ti, would the 2080 outpreform it or are they even
The base 2080 was pretty comparable, and includes Ray Tracing, which the GTX series (1080ti e.t.c) doesn't.
If it fits the budget, the 2080 Super makes the most sense to me.
