What are some of the best options for smart lights currently available.
I only need 2 or 3 lights ATM but I most likely will expand in the future.
I'm not wanting to spend Hue/Lifex money.
I'm in Australia, so if there available in Aus then that's just a bonus!
Thanks
Intel Core i7-6700K 4.0GHz Processor / Cooler Master Hyper 212X LED Cooler / ASUS Maximus VIII Hero Z170 Motherboard / TeamGroup Nighthawk 16GB (2 x 8GB) DDR4-3000 Memory / OCZ Trion 150 480GB 2.5" Solid State Drive / 2x WDBlue 500GB 2.5" 5400RPM Hard Drive (Raid 0) / EVGA GeForce GTX 1060 6GB SC GAMING Video Card / Cougar Panzar Duel Window ATX Mid Tower Case / SeaSonic 520W 80+ Bronze Fully-Modular ATX Power Supply / Microsoft Windows 10 Pro
https://linustechtips.com/topic/1107044-smart-lights/
14 hours ago, Origami Cactus said:
Well hue is not expensive, if you get white bulbs instead of colored ones.
Also they are on sale quite frequently
I'm am looking for the coloured ones
https://linustechtips.com/topic/1107044-smart-lights/#findComment-12914718
