PC wont boot 3600Mhz or above, at 3533-3466 it will, but it wont be stable, until 3333MHz 1.35V
now i suppose motherboard is good quality since i am able to boot with advertised support of 3533MHz
I'd say memory controller on CPU is bad because it stays unstable at even 3533MHz and i was wondering if i should keep trying by just increasing DRAM Voltage in BIOS?
So if any expert is here to correct me if wrong
if i cant automatically get at least 3600MHz, that means CPU is def a key factor here to turn around and say -hey u're the one screwing me over
Ryzen 5 3600 | Asus TUF B450 PRO Gaming | 16GB Patriot Steel Series Viper 3733Mhz | Intel 660P 1TB NVMe | Galax 1070 OC mini | BitFenix Whisper M 650W | Samsung LC32JG50 1440p 144hz  | Windows 10 Pro X64 |
https://linustechtips.com/topic/1106890-help-me-get-3733mhz/
Just slam DRAM voltage to 1.5V during testing. SOCK voltage needs adjusting as well, depending on CPU 1.05v-1.15v could give you better chances. Then it's timing adjustments, try raise all numbers to soemthing much larger.
Desktop benching:
https://linustechtips.com/topic/1106890-help-me-get-3733mhz/#findComment-12911858
