I was monitoring my temps the the other day and saw that I was getting up to 93c while playing games. obviously something is wrong with my kraken m22. It worked fine for almost a year until now. I already contacted NZXT support and did everything they told me to do. I re-seated the thing I shook it up. I unplugged it plugged it back in. tried different fan headers. Anything else I can try? Is it maybe clogged or something on the inside? Should I drain it and refill it? I already took an air duster and cleaned the radiator from the outside. I also tried another fan so the fan is not dying. Anything else you guys can recommend to try to fix this? I would rather not take it all off my pc and wait for them to send me a new one.
Thanks!
https://linustechtips.com/topic/1105462-help-with-fixing-high-temps/
Did you clean and reapply thermal paste?
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
Never open an AIO if you want it replaced. Cant you just sent it back to NZXT?
Please mention or quote me if you want a response. :)
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
No but I dont have thermal paste on hand. I mean it was fine for a year so I dont know why it would just rise in temps because the thermal paste. Is that possible?
You need that and just clean cpu and cooler with some paper towel. Put a blob in the middle of cpu and reseat. Check temps after.
Gaming PC:
Linux PC:
9 minutes ago, Hamface55 said:
ok thanks
And to answer your future question about what thermal paste to use. Just buy some MX-2 or any other silicon based thermal paste.
Gaming PC:
Linux PC:
