Is it normal for led backlit ips monitor to have darkish corners?
Is it normal behaviour? The top two corners have this type of darkish shade. Is this normal?
Note: There is no shadow in the middle of the screen. Its just camera interference.
It is a Bezel less benq 24in ips that uses LG Panel.
  • AMD Ryzen 7 5700X Undervolted  with PBO+Eco Mode
  • B550 Aorus Elite V2 Rev1.2
  • G.Skill TridentZ Royal 3600Mhz CL16 32gb (16gb x2)
  • MSI Mech 2X RX6600 8GB GDDR6
  • Deepcool AK620 WH
  • Deepcool CG580 WH
  • WD SN770 500gb + WD Blue 1tb HDD, Sn550 1tb + MX500 1000gb
  • Antec EAG Pro 750 80+G
  • Benq Mobiuz EX2510 144Hz
I think that it could be some type of un-clipping, lcd monitors are different panels together in a thin metal case in a monitor, there is a very small possibility to be this problem, that the metal case has opened a bit from a hit, even it could be water damage, that water can go between the panels and make this effect
3 minutes ago, Dimitrios Shizas said:
My monitor did that from high usage lifetime, mine was 17 years old but the panel is lcd, anyway, I think this is it,  how many years do you have this monitor?
Less than a week
  • Deepcool AK620 WH
  • Deepcool CG580 WH
Its most probably uneven backlit. I doubt that they dropped it as this was acquired directly from the factory warehouse.
  • Deepcool AK620 WH
  • Deepcool CG580 WH
9 minutes ago, Dimitrios Shizas said:
Oh, so this is a new monitor.
I think that they dropped it while it was in the box, maybe, it can happen
After gently pressing at hat area towards the eedge the dark shadow dissapears mostly. So this is either normal or just a feature to piss people off ?
  • Deepcool AK620 WH
  • Deepcool CG580 WH
Yeah, I bet they dropped it, monitors are having clips in that case, and maybe one or two of them are opened and maybe it needs to put them again in place, but this will void your warranty, so take this monitor back to the shop and say that you want a new one because of this
