My friend brought over his pc saying there was no signal, so I tested his rx570 4gb in my pc and it works, neat I put my rx570 8gb into his pc and still no signal, then I put in an old gt210 into his pc and it works. His pc works off onboard graphics but not off 2 amd cards, tried removing ram and still nothing, could it be his psu is dying?
https://linustechtips.com/topic/1104557-rx570-problems/
Probably the power supply can't support the wattage of the RX570. tell him to replace his PSU to a PSU with higher wattage.
https://linustechtips.com/topic/1104557-rx570-problems/#findComment-12893078
