I was looking at building a new PC and I am very intrigued with the Aorus RTX 2080 Xtreme waterforce card. I was thinking if it would even be possible to use this card along with its 240 mm radiator, if I used a NZXT x72 AIO for my cpu. The problem is will they fit in the case. I am currently looking into the NZXT H710i case, but I was hoping one of you would have the answer to "will it fit?", otherwise, what case do you think would be best for this situation? Thanks everyone!
https://linustechtips.com/topic/1103966-will-it-fit/
It should fit perfectly fine.
Radiator Support
Front: 2x 140 or 3x 120mm with Push/Pull
Top: 2x 140 or 3x 120
Rear: 1x 120
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
https://linustechtips.com/topic/1103966-will-it-fit/#findComment-12888932
