help with csgo.
Go to solution Solved by THE ELITE BAMBI,
i fixed it for the most part but i did a system restore and its alot better.
don't know what topic to put this as my bad if i'm in the wrong forum but i play csgo alot and i got a good pc its stuttering a lot i would normally get 300 fps and up but i drop to around 80 fps and it'll go up to about 150 fps and it just stutters really bad. i looked on my task manager and it says im only using 20% of my gpu i normally get 40-50%. i've tried resetting all my setting reinstalling the gpc.PNG.7ad19101bb9f482ca689abfa4146a2af.PNGame i don't know what else to try.
https://linustechtips.com/topic/1103026-help-with-csgo/
how does this behavior change with resolutions?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1103026-help-with-csgo/#findComment-12880565
3 minutes ago, THE ELITE BAMBI said:
i've tried other games to like assassins creed odyssey and i max out the settings and it runs just fine.
Yes might be botched.  Run DDU i safe mode; if possible and do a clean and restart and reboot and come back in now install latest video driver.  good luck
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1103026-help-with-csgo/#findComment-12880582
