IIS index
Solved by Catsrules,
1 minute ago, Flux Azreal said:But like the site's index how can i look at it? I don't mean an actual site called index like the ACTUAL index of the webserver.
Oh like the list of files in the web directory?
That I don't know, it has been awhile. I am not sure if it is possible if you have a default html file setup. I think you can do it on sub directory.
For example http://site/files/ but not the root if the default html has been setup.
You might be able to setup a secondary domain name that would go to the same place but IIS will treat it differently and not have default html page on that site. I think you can do that on IIS but I personally have never done it.
