my little case is as full as it can be, you can check out my build log.
So i was thinking to get a new case & psu & cpu cooler (maybe)
everything else pretty much goes from the one thing to the other thing.
case: corsair 750
psu: corsair ax 860 or rm 850
cpu cooler: h105
maybe considering a soundcard, but i think my motherboard has good enough audio, that i wouldn't not notice the difference.
any thoughts or suggestions?
i haven't orderd anything so shoot :)
edit: i digged arround and found that the rm 850 has nicer cables and is cheaper then the ax;   so i'm thinking i'll go for the rm
I7 3930K @4.4 GHz  /  Asus rampage 4 formula  / 4x 8gb kingston hyperx blue low profile / gtx 980  / 2x ssd 500gb samsung 840 / 500gb 840evo ssd   /  500 GB WD blue /  windows 7 ultimate
my build: http://linustechtips.com/main/topic/133477-750d-finished/
https://linustechtips.com/topic/110201-rebuilding-my-current-case/
what is your budget?
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
there is no budget, look at my specs, do i look like a man on a budget? :P
It looks pretty good.  I would get the AX 860i over the AX 860, its only $10 extra in the U.S.
i was thinking about that to, but i just don't think i would use the options on it
Fair enough.  I think it's good then.
The only other thing would do a custom water loop w/ your GPUs, but that would be a little too much $$ for the little preformance gain.  :P
yeah, it's to much money for "nothing" really :)
