So i bought an i7 9700k and an asus z390-a moba, i installed then into my pc and now when i try to turn my pc on i get to the windows logo and then it says ”preparing automatic repair” and then it loads for a little while and then it freezes. Later i just get the sad simly face screen xd
https://linustechtips.com/topic/1101871-please-help-me/
Have you treied a fresh install of windows? or even a repair?
Folding Stats
SYSTEM SPEC
AMD Ryzen 5 5600X | Motherboard Asus Strix B550i | RAM 32gb 3200 Crucial Ballistix | GPU Nvidia RTX 3070 Founder Edition | Cooling Barrow CPU/PUMP Block, EKWB Vector GPU Block, Corsair 280mm Radiator | Case NZXT H1 | Storage Sabrent Rocket 2tb, Samsung SM951 1tb
PSU NZXT S650 SFX Gold | Display Acer Predator XB271HU | Keyboard Corsair K70 Lux | Mouse Corsair M65 Pro
Sound Logitech Z560 THX | Operating System Windows 10 Pro
https://linustechtips.com/topic/1101871-please-help-me/#findComment-12870288
3 minutes ago, Sandberg said:
No i just kept the old hdd, also im not very good with computers hehe
Usually best to do a fresh install of windows when changing motherboard. you can sometimes get away with it, but not always.
Folding Stats
SYSTEM SPEC
https://linustechtips.com/topic/1101871-please-help-me/#findComment-12870301
On 9/6/2019 at 10:03 AM, Sandberg said:
So i should install the windows tool on a usb and just boot from that insted?
Yeah use the Windows tool , you could try a repair form that , but personally I would do a fresh install
Folding Stats
SYSTEM SPEC
https://linustechtips.com/topic/1101871-please-help-me/#findComment-12875953
