Any help for a newbie? (Solved)
Solved by Arden Fox,
1 minute ago, Arden Fox said:I can't get to the point where I can format it is the problem... and yes I moved it to be my first boot priority, however I'm booting currently off a flashdrive that has the Windows 10 Installer on it.
HOWEVER,
Thank you for the help, but the drive is magically working now >.> Apparently it only took rebooting 12 times
And literally as I was typing that, the installation froze and the drive disappeared... bad sata maybe? or bad power connection?
