I just built my pc, and I have been using it for the past couple of days and have noticed no immediate problems involving temperatures; However, yesterday i couldn't play any games for more than 15 minutes without my Mainboard temperature reaching 80+C and completely rebooting my system. I removed all overclocking that i had done and I'm still getting the same result.
My CPU temp idles at 33C
GPU: 34C
Mainboard: constantly climbing, starting from 50C
Any help would be great
My setup is: Ryzen 3700x
Corsair H115i
Taichi x570
G skill Trident z Neo 3600
5 working case fans (Not enough 4 pin connectors)
FTW3 RTX 2070 Super
https://linustechtips.com/topic/1101663-mb-overheating-problem-please-help/
GPU: 34C
Corsair H115i
Taichi x570
FTW3 RTX 2070 Super
That is insane 80c for mobo temp, wtf........ Im shocked it didn't blow up.  What app you using to get the temp and what not.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
7 minutes ago, YLN_Flacko said:
It would read 75 in the "SB Temperature" in bios.
that's the chipset. Is the graphics card sitting right above the chipset fan?
Desktop benching:
Is the fan even working?
Folding Stats
SYSTEM SPEC
AMD Ryzen 5 5600X | Motherboard Asus Strix B550i | RAM 32gb 3200 Crucial Ballistix | GPU Nvidia RTX 3070 Founder Edition | Cooling Barrow CPU/PUMP Block, EKWB Vector GPU Block, Corsair 280mm Radiator | Case NZXT H1 | Storage Sabrent Rocket 2tb, Samsung SM951 1tb
PSU NZXT S650 SFX Gold | Display Acer Predator XB271HU | Keyboard Corsair K70 Lux | Mouse Corsair M65 Pro
Sound Logitech Z560 THX | Operating System Windows 10 Pro
Thanks a ton! I got it fixed. I ran cinebench twice and im chilling at 58C. I need to invest in a vertical mount since my graphics card is a 3 slot, so moving it down to the middle slot is making it too close to the bottom fans. but thats an issue for later.
4 minutes ago, YLN_Flacko said:
vertical mount
vertical mount that replaces the entire PCIe bracket? Please dont use those right next to the side panel, chokes the fans.
Desktop benching:
