I’m having CPU usage problems
Solved by Fasauceome,
Damn gotta download your parts list? I suggest replacing that with a good old pcpartpicker list.
As for the download using up all CPU resources, not surprising. The 8350 has a lot of shared resources between the cores so once the download is over with you will see the usage go down, but I believe there's a download speed limiter in the epic games launcher that will make it so that the CPU is handling a lot less data all at once.
