I am going to be building a desktop soon and in need of some advice. I have home WiFi but it is literally garbage, so recently I have resorted to using my phone hotspot for gaming on my laptop and xbox, because it is much faster and better ping. So I was wondering should I look for a motherboard with WiFi built in, but I’ve heard that this isn’t always very fast or should I go with like a PCI WiFi adapter card, or what would you guys recommend I do?
https://linustechtips.com/topic/1100769-help-please/
Consider running an ethernet cable, or if not possible, try one of those wifi boosters so you don't use up your mobile data.
For the wifi on the computer, either built in motherboard wifi or a wifi pci card both will work equally as well, go for whichever one is cheaper.
linus sex tips
https://linustechtips.com/topic/1100769-help-please/#findComment-12862048
