Formatting an SSD from old system
By
Naxy
in Storage Devices
in Storage Devices
Solved by Mokomoko,
You can do that, make sure to either change your boot priority in the BIOS to your primary HDD or use the Boot Menu (F12 usually during booting) to choose your primary HDD. Using that you can then easily format the HDD. You could also boot into safe mode, or command line mode, and then do it from there, but that would be a little bit more challenging.
Featured Topics
PapaAquaWet ·
Posted in Graphics Cards0 -
Average Nerd ·
Posted in Build Logs0 -
5
1
5
alexfic ·
Posted in New Builds and Planning3 -
1
