Hi All,
Here is an attempt at a propsed first build: https://pcpartpicker.com/list/P2VVq4
It is intended to run 2x32inch displays. I am trying to keep the PC budget to around 2000-2500AUD.
I inted to use it for light-moderate gaming (DOTA 2 etc) as well as for productivity/work.
Any advice would be appreciated :)
https://linustechtips.com/topic/1100118-advice-needed-for-first-build/
Welcome to the forums!
What kind of work do you do? Depending on the software your specs will change a bit, though you'll definitely want a higher-end CPU. I commend your good PSU choice :)
You can definitely save money on the motherboard and cooling. That all depends on how much budget you want to allocate to aesthetics. The way I do it is say "X money is for aesthetics" and then if I make a choice that's more expensive than the non-bling equivalent, I subtract the difference from the RGBudget.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
you don't need a taichi and 240mm AIO just for a 2600x. what programs are you using?
For instance, this non-bling build makes room for a much more powerful Ryzen 7 3700X CPU, while keeping the price around the same.
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($517.00 @ Shopping Express)
CPU Cooler: be quiet! Shadow Rock Slim 67.8 CFM Rifle Bearing CPU Cooler  ($65.00 @ PCCaseGear)
Motherboard: MSI MPG X570 GAMING PLUS ATX AM4 Motherboard  ($284.00 @ Shopping Express)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  ($112.54 @ Amazon Australia)
Storage: Samsung 970 Evo 500 GB M.2-2280 NVME Solid State Drive  ($148.95 @ Amazon Australia)
Storage: Western Digital RE 2 TB 3.5" 7200RPM Internal Hard Drive  ($63.45 @ Amazon Australia)
Video Card: MSI Radeon RX 5700 8 GB MECH OC Video Card  ($596.00 @ Skycomp Technology)
Case: Corsair Carbide Series 275R ATX Mid Tower Case  ($113.00 @ Austin Computers)
Power Supply: Cooler Master MWE Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($144.00 @ Shopping Express)
Total: $2043.94
Generated by PCPartPicker 2019-09-01 16:19 AEST+1000
Also gave you a 2TB Hard Drive, that branding is for workstation / server CPUs. I have one (an RE4) that I got after RMAing my old drive, and it's high performance for a hard drive, I've had no problems with it.
EDIT: This is an amazing deal for a PSU https://au.pcpartpicker.com/product/3zNypg/corsair-power-supply-cp9020090na
Computer Specs:
With a much cheaper SSD and no cooler (if you go for the shadow rock slim, might as well keep the prism) then suddenly you can fit a 5700XT
Primary PC:
PSU tier list
How many watts do I need?
4 minutes ago, Fasauceome said:
That looks pretty good
Actually I'd consider a Deepcool Gammaxx 400, it scored higher performance than the Shadow Rock Slim and the NH-U12S and it's super cheap
https://au.pcpartpicker.com/product/hJFPxr/deepcool-cpu-cooler-gammaxx400
Computer Specs:
