3 minutes ago, Burnedice25 said:
I’ve a,ready asked for help in an earlier topic, but the issue was not resolved so I’m trying again.
there’s a link to the earlier topic, give that a read (don’t worry, it’s short) and please help.
cheers
Run memtest86 from a bootable pen drive.
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8800Mhz Watercooled
GPU: RTX 5090 Palit OC with Alphacool Core Waterblock
Case: TT P3
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 57" 240Hz Ver. 7680x2160 and
2x ASUS XG17AHP 240hz 17"
Fan Controllers:  6x AquaComputer Octo
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3x 360mm PE EKWB CoolStream
3rd Loop: 1x 240mm PXE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY) - Back of the case
2nd Main PC is same as above, except Display is Philips Evnia 49" 5120x1440 240hz QD-OLED, 48GB 8400Mhz RAM, 8TB NVMe
1st LaptopMSI Titan HX18 Dragon EditionRTX 5090 175W, Core Ultra 285HX,  128GB of RAM @5600Mhz / 96GB @6400Mhz
8TB of NVMe - GPU and CPU with LM on, Llano V12
2nd Laptop: MSI Raider 18HX, RTX 5090 175W, 9955HX3D, 128GB DDR5 @5600Mhz, 8TB NVMe, CPU and GPU LM on, Llano V12
3rd Laptop: MSI Titan 18HX, RTX 4090 175W, 14900HX, 224GB DDR5 @3600Mhz, 8TB NVMe
HTPC:
CPU: Intel Core i9 14900K (SP99 P111 E76), CPU Voltage: 1.33V, Cooled by: Supercool Direct Die 12th gen full nickel, Motherboard: Z790 Apex
RAM: GSkill TridentZ 2x24GB DDR5 8000Mhz CL40, GPU: RTX 5090 Palit Gamerock with Alphacool Waterblock,  Case: Corsair 6500D, Storage: 3x2TB PM9A1 Samsung NVMe Gen 4
WiFi: Wifi 6E Built in, PSU: AX1600i Corsair Titanium, Display: Philips Evnia 49" 240Hz OLED, Fan Controllers:  1x DH-10 DeepCool and Deepcool RGB hub, Loop: 2x 360mm XE CoolStream radiator, 1x 360mm PE Coolstream Radiator, 1x 240mm XE CoolStream Radiator, Revo D5 EKWB Pump, 19x Corsair 120ML RED LED fans 2000RPM
https://linustechtips.com/topic/1099491-help/#findComment-12852044
2 minutes ago, Burnedice25 said:
What will that do? I’ve already run a different RAM test and that one said I was fine
Don't do it if you don't want to then.
It tests memory, as name specifies. For many hours.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/1099491-help/#findComment-12852054
1 minute ago, Burnedice25 said:
Anything else I can do as the test said it was fine
I don't think so. Change slots on the motherboard, use different ram slots.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/1099491-help/#findComment-12852060
I agree with memtest86. At least 4 passes minimum but better to run overnight - it will give you a clear answer if ram is faulty or not.
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1099491-help/#findComment-12852075
Like I’ve said before, I’ve already tested the ram and there’s nothing out of the ordinary. What else can I do?
https://linustechtips.com/topic/1099491-help/#findComment-12852085
Return the RAM or motherboard is faulty or RAM is incompatible.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/1099491-help/#findComment-12852089
With what software did you test your ram?
https://linustechtips.com/topic/1099491-help/#findComment-12852093
BIOS onboard RAM tester
Please run memest86 before RMA’ing either the board or ram.
memtest86 is much more thorough than the onboard windows/bios one. I recommend running it for 12h
https://linustechtips.com/topic/1099491-help/#findComment-12852133
It's strange because he asks for help, we tell him what needs to be done and he doesn't do it. Bizarre world we live in.
I don't think he knows what memtest86 is. Googling it takes like 1 minute.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/1099491-help/#findComment-12852135
Also, here's me trying to memtest 4500mhz ram, and LOTS of issues came up later later on during the test.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/1099491-help/#findComment-12852145
