So my computer eats up my bandwidth or attleast the speed i am paying for but it cant seem to go much higher even though it is eating all that i am paying for  max down is 80 and max up is 35-40 but as soon as i start to download on steam or somewhere else it keeps the speed at 1 or 3 mb/s and i cant even load google while that is happening .. any one knows a solution to this ?
https://linustechtips.com/topic/1099490-internet-problem/
Steam will eat up all your bandwith, but u can throttle that in the settings.
Also your router and Steam both use a different way to show u the speed:
Router -> Mb/s so thats bits per second
Steam -> MB/S and thats bytes per second.
Multiply the Steam speed by 8 and you get the Mb/s speed.
Still, thats 19,2 Mb/s so with 80 Mb/s you should have more then enough overhead.
How is your computer connected to the router? Wired or Wireless? And what does the link speed say (on the PC)
https://linustechtips.com/topic/1099490-internet-problem/#findComment-12852088
sorry for the late reply i am wired :D
https://linustechtips.com/topic/1099490-internet-problem/#findComment-12865293
On 8/30/2019 at 8:04 PM, DrDrummer said:
try to run an internet speed test somewhere in the web. what are the results ?
i have run many speed tests but i cant run it when i am downloading on steam it will tell me there is a ping error so steam when downloading on my computer that is wired connected will just tank
https://linustechtips.com/topic/1099490-internet-problem/#findComment-12865296
On 8/30/2019 at 7:39 PM, Grand Admiral Thrawn said:
If you don't have any personalized rules, it may be QoS fault. Try turning it off and see if the situation improves. From experience, I know that QoS without rules doesn't prioritize the download speed but rather equalize bandwidth on all devices. If you have only one device using the connection then QoS is not necessary.
i will try to disable QOS maybe that might be the problem
https://linustechtips.com/topic/1099490-internet-problem/#findComment-12865299
link speed ? how do i get that info ?
https://linustechtips.com/topic/1099490-internet-problem/#findComment-12865302
here is a photo of what i get but when i start to download on steam i can take the speed test but when i try the upload crashes completely... and these are the results from the IPS
https://linustechtips.com/topic/1099490-internet-problem/#findComment-12865318
