22 minutes ago, Chazdor said:
Heron's Fountain: a series of siphons connected so that one feeds the others https://imgur.com/gallery/Likf8ng
Might this be able to be applied to create a loop without a pump?
Welcome to the Forums!
That works well as there is no restriction in that setup but in a watercooling loop that had dense fin arrays and tight bends/corners those losses will add up making it not possible. There are pumpless water coolers per say using low boiling point fluids that evaporate and condense in a fin array for cooling.
