So my base system is
MSI Z97 chipset motherboard
intel i5 4600 (3.6 - 3.8ghz) 4 core
12gb DDR3 RAM
GTX 960 2gb ---> upgrade to a GTX 1070TI
650 W PSU
No im looking to upgrade from ddr3 and L1150 Socket to a DDR4 setup and either a Coffee Lake L1151 or Am4 socket
So i live in south africa and the best parts for price and performance currently is
MSI tomahawk B450 chipset motherboard
Ryzen 5 3600x
16gb 3200mhz ddr4 ram
^ Now i believe those specs are a good upgrade for the price. The one thing im worried about is ive been running the same 650w psu for 4-5 years now is it worth getting a new one or is a Corsair vs650 perfectly fine.
any other recommendations for parts would be nice.
https://linustechtips.com/topic/1099239-upgrade-advice/
12gb DDR3 RAM
650 W PSU
Ryzen 5 3600x
How much is the difference between a 3600x and a 3600 in your country?
And the psu is not that good, and put that together with the fact you've been running it for 5 years, i think it'd be time to change it
https://linustechtips.com/topic/1099239-upgrade-advice/#findComment-12850009
