First time build help
Go to solution Solved by Herman Mcpootis,
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  (£115.34 @ CCL Computers) stock cooler is good enough.
Motherboard: MSI B450-A PRO ATX AM4 Motherboard  (£79.99 @ CCL Computers)
Memory: *G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3000 Memory  (£65.94 @ Amazon UK)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive  (£97.97 @ CCL Computers)
Video Card: XFX Radeon RX 5700 XT 8 GB Video Card  (£371.99 @ Amazon UK)
Case: Fractal Design Meshify C ATX Mid Tower Case  (£79.99 @ Amazon UK)
Power Supply: Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  (£64.97 @ Amazon UK) 550w is good enough for a rig with a single GPU.
Total: £876.19
Generated by PCPartPicker 2019-08-28 14:37 BST+0100
Hi, first time posting so be nice. Any suggestions on this would be appreciated.
This is what I have so far:
https://uk.pcpartpicker.com/user/Frostyfeet909/saved/3DZDxr
CPU: Ryzen 5 2600X - £134
Cooler: Deepcool Gammax 400 - £23
Motherboard: MSI B450-A Pro - £80
Memory: G.skill DDR4 16GB 3000Mhz - £65
Storage: Intel 660p 1TB SSD - £98
GPU: Gigabyte GTX 1660Ti 6GB OC - £275
Case: Meshifly C - £80
PSU: Corsair TMX 750W 80+ Gold - £80
1. Budget & Location
I live in the UK and I'm going for a budget of around £800-£900.
2. Aim
I want to use this mainly for gaming (Monster hunter world, World of Warcraft, Rimworld etc.) but I'll also be doing some university work on here, mostly just writing up reports and some browsing.
3. Monitors
Only 1 monitor at the moment 1080p 60Hz but I'm planning on getting another one in the next couple of months.
4. Peripherals
Standard Keyboard and mouse is all I'll be using and I already have windows. So don't take OS or any peripherals into account for the budget.
5. Why are you upgrading?
New build, wanting to get away from my awfull laptop.
https://linustechtips.com/topic/1098847-first-time-build-help/
2. Aim
Budget for just pc of include monitor keyboard mouse etc.?
https://linustechtips.com/topic/1098847-first-time-build-help/#findComment-12846923
Total: £876.19
https://linustechtips.com/topic/1098847-first-time-build-help/#findComment-12846989
Total: £876.19
That looks so much better Thanks!
Would it be worth spending £10 more on the GPU for one manufactured by MSI or will they preform the same?
https://uk.pcpartpicker.com/product/z6XYcf/msi-radeon-rx-5700-xt-8-gb-video-card-radeon-rx-5700-xt-8g
https://linustechtips.com/topic/1098847-first-time-build-help/#findComment-12847066
the cooler is the same so they perform exactly the same. you can go with a different company if they offer better support in the UK but i wouldn't worry about it.
https://linustechtips.com/topic/1098847-first-time-build-help/#findComment-12847092
Cool :)
Looks like this is what i'll be going with then thanks for all the help!
https://linustechtips.com/topic/1098847-first-time-build-help/#findComment-12847100
Cool :)
if you can spend the extra, pick up the 5700xt thicc II instead, the reference 5700XT isn't good.
https://linustechtips.com/topic/1098847-first-time-build-help/#findComment-12847109
