Interesting! Looks like they're meant to be about the same otherwise, judging by the information available.
Compare the two Scan pages for the model numbers:
https://www.scan.co.uk/products/see-new-model-2tb-seagate-st2000dm006-barracuda-35-hdd-sata-iii-6gb-s-7200rpm-64mb-cache-95ms
https://www.scan.co.uk/products/3tb-seagate-barracuda-35-hdd-sata-iii-6gb-s-7200rpm-64mb-cache-95ms-ncq-oem
Sig under construction.
https://linustechtips.com/topic/1098677-3tb-cheaper-than-2tb/#findComment-12845631
Just now, The Torrent said:
i also noticed the 4tb is cheaper than the 2tb
The normal Barracuda one, yes; though the Pro...definitely not ?
They're not making it that clear, though the price difference absolutely is.
https://linustechtips.com/topic/1098677-3tb-cheaper-than-2tb/#findComment-12845633
