Is a i5 3570k going to bottleneck a gtx 1660 ti
Solved by thx1138,
a 1660ti is not a price/performance GPU right now....The Vega 56 would be a much better price/perf. or upgrade to a 5700/5700xt or even a 2060$uper........or even downgrade to a 580 or 570(or go used.)
if playing new games that utilize mutl-core then you are definitely leaving performance on the table......but if your at least planning an upgrade at some point within the next 8 months....
I would probaby see about a used GPU to pair with that system (like a 980 or a 1060 6g ) and sell that system when upgrading full system later.
